Click to visit BT.com
BT.com
Wishlist
Akasa NERO LX, Multi platform lower profile cooler with 120mm fan
Quicklinx: 8MRDWS00
Mfr#: AK-CC4011EP01
  • High performance low profile four direct contact heatpipes cooler with only 59mm tall
  • Suitable for HTPC or slim system with limited space
  • For all LGA1366, LGA1156, LGA1155, LGA775 AMD AM3+, AM3, AM2+, AM2, FM1
  • Low noise 12cm slim PWM fan - High performance thermal compound included
Specification
Socket type - Intel LGA775, LGA1155, LGA1156 & LGA1366 AMD Socket AM2, AM2+, AM3 & FM1
Heatsink material - Aluminium fins, copper heatpipes
Cooler weight - 298g
Cooler dimension - 120 x 120 x 59mm (W x D x H)
Fan dimension - 120 x 120 x 18mm Fan speed - 600 - 1900 RPM
Max airflow - 64.12 CFM
Max air pressure - 2.04 mm H²O Noise level - 11.50 - 31.50 dB(A)
Voltage rating - 12V DC
Bearing type - EBR
Fan connector - 4pin PWM
Akasa NERO LX - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket FM1
Heatsink Material
Aluminium and copper
Fan Diameter
120 mm
Fan Height
18 mm
Fan Bearing
EBR bearing
Rotation Speed
600-1900 rpm
Air Flow
64.1 cfm
Noise Level
11.5 - 31.5 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm)
12 cm x 12 cm x 5.9 cm
298 g
Processor cooler
Package Content
Thermal paste
12 cm
12 cm
5.9 cm
298 g
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
18 mm
Fan Bearing
EBR bearing
Rotation Speed
600-1900 rpm
Air Flow
64.1 cfm
Air Pressure
2.04 mm
Noise Level
11.5 - 31.5 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
