BT.com
Wishlist
Akasa Nero 3 Premier CPU Cooler (Intel LGA775/1155/1156/1366/2011 + AMD AM2, AM2+, AM3 & FM1)
Delivery
Standard Due date unavailable
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminium profiled fins ensure optimum heat dissipation. A piano black 120mm PWM fan is mounted using anti-vibration siliconized rubber pins giving whisper quiet cooling.
The product design has been refined to ensure ultra quiet and exceptional cooling for CPU's up to 150W TDP (Thermal Design Power). It is compatible with the new forthcoming Intel LGA 2011 processors. Akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1155, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
  • Four high capacity 6mm heatpipes with direct CPU contact
  • Piano black 12cm fan with PWM
  • Siliconized rubber fan mounts for enhance ultra quiet performance
  • Socket type Intel LGA775, LGA1155, LGA1156, LGA1366 & LGA2011
  • AMD Socket AM2, AM2+, AM3 & FM1
  • Cooler dimensions 120 (W) x 86.7 (D) x 160 (H) mm
  • Heatsink material High grade aluminium fins, copper heatpipes
  • Heatpipe 6mm x 4
  • Weight 609g
  • Installation Push pins (Intel LGA775 / 1155 / 1156 / 1366)
  • Screws (Intel LGA2011)
  • Cam-lever clip (AMD)
  • Fan dimension 120 x 120 x 25mm
  • Fan speed 500-1500 RPM (PWM controlled)
  • Max airflow 50.54 CFM
  • Max air pressure 1.32 mm H2O
  • Noise level 24.6 dB(A)
  • Voltage rating DC 12V
  • Bearing type EBR
  • Fan life expectancy 40,000 hours
  • Fan connector 4pin PWM
Akasa NERO 3 - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
500-1500 rpm
Air Flow
50.5 cfm
Noise Level
24.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm)
12 cm x 8.7 cm x 16 cm
0.61 kg
Anti-vibration, Easy Select Clip
Processor cooler
Package Content
Thermal paste
12 cm
8.7 cm
16 cm
0.61 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Quad , Core i3 , Core i5 , Core i7 , Athlon 64 , Athlon 64 FX , Athlon II , Phenom , Pentium II
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
500-1500 rpm
Air Flow
50.5 cfm
Air Pressure
1.32 mm
Noise Level
24.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Cooler The Better.
Reviewed by Peter on 23/01/2013
I recently purchased this cooler merely because I read what PC manufacturers in the PC Pilot magazine where using in their machines.Yes, I am a flight simmer.I noticed an immediate difference after this was fitted both in noise and heat production.The fan was tricky to fit, and it is quite large.But overall for the price it is fantastic. Plus it is also compatible with so many more CPUs.
3* Great CPU cooler, but pretty big.
Reviewed by Anonymous on 20/08/2012
I was just making my computer and the cooler was so big, it took up some of the RAM slots. I'm sure its a great cooler though.
1* Very poor cooler for LGA1155
Reviewed by Chris Jones on 23/03/2013
It may be a quiet cooler but mounting it on P8Z77-V S1155 mobo is virtually impossible. The instructions about mounting it on the board are just wrong and I found feeding the flimsy rubber mountings into the mounting holes in the fan when it is virtually inaccessible in the case was very difficult. It took longer to try and mount the fan than to build the rest of the system. In the end I gave up.
Scroll to top
