BT.com
Wishlist
Akasa NERO 3  Multi platform, 4 direct contact HP with Piano Black
Akasa NERO 3 Multi platform, 4...
£30.98
£30.98
Add to wishlist
Delivery
Standard Due date unavailable
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminum profiled fins ensure optimum heat dissipation.
Akasa NERO 3 - processor cooler
Processor cooler
Package Content
Thermal paste
Piano black
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1
Heatsink Material
Aluminium and copper
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
500-1500 rpm
Air Flow
50.5 cfm
Noise Level
24.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm)
12 cm x 8.67 cm x 16 cm
609 g
Processor cooler
Package Content
Thermal paste
12 cm
8.67 cm
16 cm
609 g
Piano black
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
500-1500 rpm
Air Flow
50.5 cfm
Air Pressure
1.32 mm
Noise Level
24.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
MTBF
40,000 hour(s)
Akasa NERO 3 Multi platform, 4 direct contact HP with...
£30.98
Save on this ideal PC Build kit!
Save £10.63
£50.15
Scroll to top
