BT.com
Wishlist
Akasa Max MT Fanless Ali case for Intel NUC (Board Specific)
Akasa Max MT Fanless Ali case for...
£96.13
£96.13
Add to wishlist
Delivery
Standard Due date unavailable
Max MT fanless case for Intel® NUC 2 bay 2.5" SATA mobile tray
  • Aluminium fanless CPU cooling design
  • Stylish front panel diamond effect
  • Two bay 2.5" SATA mobile tray
  • Support one serial port
  • Support IR remote function
  • Compatible with the following Intel® NUC Board: NUC5i5MYBE / NUC5i5MYHE / NUC5i3MYBE / NUC5i3MYHE / NUC5i5RYH / NUC5i5RYK / NUC5i3RYH / NUC5i3RYK
Akasa Max MT - ultra small form factor - UCFF
Ultra small form factor
Max Mainboard Size
UCFF
Supported Motherboards
UCFF
Hot-Swap Bays Qty
2
System Cabinet Features
VESA mounting interface, Kensington lock support, aerial fitting holes, IR receiver window
Expansion Bays
2 (total) / 2 (free) 2.5"
2 x USB 3.0 , 1 x audio line-out/line-in - mini-jack
2 x SATA cables, SATA power cable, serial cable, M.2 to SATA adapter, HDD protective film x 2
No power supply
17.46 cm
17.9 cm
7.96 cm
1.915 kg
Akasa Max MT Fanless Ali case for Intel NUC (Board...
£96.13
Save on this ideal PC Build kit!
Save £8.43
£115.35
Scroll to top
