Click to visit BT.com
BT.com
Wishlist
Akasa Low Profile Cooler for mini-ITX & micro-ATX Cases
Quicklinx: 7PPWWS00
Mfr#: AK-CC7118HP01
Type: CPU Cooler
£11.04
K25: Designed for mini-ITX and micro-ATX chassis
  • Core 2 Duo, Core i3 & Core i5 processors
Ultra compact and low noise cooler for Intel Core 2 Duo, Core i3 and Core i5 (73W) CPU's. The low profile design with embedded S-Flow fan makes it a perfect solution for mini-ITX, HTPC and SFF systems.
Aluminium heatsink with full height copper core and quiet HDB bearing fan ensure high efficiency and long life. High engineered multi directional aluminium heatsink maximizes heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
Intel approved pushpins ensure easy installation, reliable retention and maximum compatibility on both LGA775, LGA1155 and LGA1156 platforms without any mounting adjustment, pushpins will automatically slide into correct position. K25 is designed to work with CPU's up to 73W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
  • For Intel LGA775, LGA1155, LGA1156
  • Embedded 8cm PWM fan with S-Flow blades and long life bearing
  • Intel approved push pins provide maximum compatibility
  • High performance thermal interface is pre-applied
  • Socket type Intel LGA775 , LGA1155, LGA1156
  • Cooler dimension 87.2 x 85.2 x 29.5 mm
  • Heatsink material Aluminum with copper insert
  • Weight 220 g
  • Installation Push pins
  • Fan dimension Ø74 x 15 mm
  • Fan speed 600 - 3000 RPM (PWM controlled)
  • Max airflow 33.50 CFM
  • Max air pressure 3.76 mmH2O
  • Noise level 28.71 dB(A)
  • Voltage rating 12V DC
  • Bearing type HDB
  • Fan life expectancy 50,000 hours
  • Fan connector 4pin PWM
Akasa K25 AK-CC7118HP01 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium with copper base
Fan Diameter
74 mm
Fan Height
15 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-3000 rpm
Air Flow
33.5 cfm
Noise Level
28.7 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
8.7 cm x 8.5 cm x 3 cm
220 g
Processor cooler
8.7 cm
8.5 cm
3 cm
220 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo , Core i3 , Core i5
Heatsink Material
Fan Diameter
74 mm
Fan Height
15 mm
Fan Bearing
Rotation Speed
600-3000 rpm
Air Flow
33.5 cfm
Air Pressure
3.76 mm
Noise Level
28.7 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Akasa Low Profile Cooler for mini-ITX & micro-ATX Cases Bundle deal on Akasa Low Profile Cooler for mini-ITX & micro-ATX Cases
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£30.57
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£15.13
saving £1.39
Type: CPU Cooler
Brand: Akasa
Price Range Inc VAT: 0 - 50
