BT.com
Wishlist
Akasa K32 High Perf Cooler w/ 92 PWM Killer Viper Yellow Fan
Akasa K32 High Perf Cooler w/ 92...
£10.08
£10.08
Add to wishlist
Delivery
Standard Due date unavailable
K32 uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. Low noise 9.2 cm PWM fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
K32 is designed to work with CPU's up to 95 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Akasa K32 AK-CC7117EP01 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Entering bearing
Rotation Speed
600-3000 rpm
Air Flow
57 cfm
Noise Level
17.2 - 30.54 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9.5 cm x 9.5 cm x 6.2 cm
326 g
Processor cooler
9.5 cm
9.5 cm
6.2 cm
326 g
Heatsink & Fan
Compatible With
Processor Compatibility
Pentium 4 , Core 2 Duo , Core 2 Quad , Core i3 , Core i5
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Entering bearing
Rotation Speed
600-3000 rpm
Air Flow
57 cfm
Air Pressure
4.1 mm
Noise Level
17.2 - 30.54 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Akasa K32 High Perf Cooler w/ 92 PWM Killer Viper...
£10.08
Save on this ideal PC Build kit!
Save £10.76
£29.25
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Not quite as good as stock Intel cooler
Reviewed by Anonymous on 24/08/2013
I bought this hoping to knock 10C off my CPU temperatures but it actually ran 4C hotter than the stock cooler. Good value for money if you have no cooler at all but probably need to spend twice the money on a better quality unit to see a decent reduction in temperatures.
Scroll to top
