BT.com
Wishlist
Akasa Intel LGA775/1156, Lo Noise AliCore HS with PWM EBR Fan
Akasa Intel LGA775/1156, Lo Noise...
£10.44
£10.44
Add to wishlist
Delivery
Standard Due date unavailable
It offers ultra compact and low noise cooler for Intel Core 2 Duo and Core i3 CPU's. The low profile design with embedded fan makes it a perfect solution for mini-ITX, HTPC and SFF systems.
Aluminum heat-sink and enter bearing fan ensure high efficiency and long life. High engineered multi directional aluminum heat-sink maximizes heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
Akasa AK CC7122EP01 - processor cooler
Processor cooler
Package Content
Tool-less fixed pins
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
75 mm
Fan Height
10 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
23.5 cfm
Noise Level
30.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Copper core heatsink
8.52 cm x 8.72 cm x 2.6 cm
152.8 g
Processor cooler
Package Content
8.52 cm
8.72 cm
2.6 cm
152.8 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo - all speeds , Core i3 - all speeds
Heatsink Material
Aluminium
Fan Diameter
75 mm
Fan Height
10 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
23.5 cfm
Air Pressure
1.81 mm
Noise Level
30.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.19 A
MTBF
40,000 hours
Scroll to top
