BT.com
Wishlist
Akasa Intel LGA 1366 Copper Core multidirectional heatsink with open frame PWM Fan
Delivery
Standard Due date unavailable
AK-980 uses a high engineered heatsink with a large full height copper core and aluminum fins. The Omni-directional heatsink ensures airflow is directed to all motherboard components located around CPU (like voltage regulators), which is crucial for keeping the system stable and functioning up to full potential. Each aluminum fin splits into two (bi-ped) to double the dissipation area.
A large 10.7cm open frame fan provides increased airflow with minimal noise. The PWM fan function ensures the RPM is automatically regulated by the motherboard according to system usage and temperature. This means under normal operating conditions, the CPU fan speed is relatively low maintaining low noise levels.
Intel approved board push pins ensures reliable retention and easy installation.
Akasa AK 980 - processor cooler
Processor cooler
Compatibility
LGA1366 Socket
Heatsink Material
Aluminium and copper
Fan Diameter
107 mm
Fan Height
25 mm
Fan Bearing
Ball bearing
Rotation Speed
900-5000 rpm
Air Flow
17.9-99.1 cfm
Copper core heatsink, Pulse-width modulation (PWM) support
Processor cooler
Heatsink & Fan
Compatible With
LGA1366 Socket
Processor Compatibility
Core i7 , Core i7 Extreme Edition
Heatsink Material
Heatsink Dimensions
95 mm x 95 mm x 41 mm
Fan Diameter
107 mm
Fan Height
25 mm
Fan Bearing
Ball bearing
Rotation Speed
900-5000 rpm
Air Flow
17.9-99.1 cfm
Sound Emission
18.3 dBA
Scroll to top
