BT.com
Wishlist
Akasa Intel 2U all copper active cooler for LGA2011 w/70mm PWM fa
Akasa Intel 2U all copper active...
£36.56
£36.56
Add to wishlist
Delivery
Standard Due date unavailable
2U chassis server cooling solution for Intel LGA2011 motherboards. Copper heatsink designed for rackmount or workstations chassis. Long life PWM fan provides acurate cooling. Pre-applied spring-loaded screws and motherboard backplate guarantee safe retention.
  • Active LGA2011 cooling solution for 2U chassis
  • 7cm fan with automatic PWM speed control
  • Solid copper heatsink
  • Reliable and long life twin ball bearing
Akasa AK CC6502BP01 - processor cooler
Processor cooler
Package Content
Thermal grease
Compatibility
LGA2011 Socket
Heatsink Material
Copper
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1000-5000 rpm
Air Flow
37.2 cfm
Noise Level
42.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9 cm x 8.9 cm x 4.25 cm
582 g
Processor cooler
Package Content
Thermal grease
9 cm
8.9 cm
4.25 cm
582 g
Heatsink & Fan
Compatible With
LGA2011 Socket
Heatsink Material
Copper
Fan Diameter
70 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1000-5000 rpm
Air Flow
37.2 cfm
Air Pressure
6.015 mm
Noise Level
42.4 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
MTBF
65,000 hour(s)
Akasa Intel 2U all copper active cooler for LGA2011...
£36.56
Save on this ideal PC Build kit!
Save £16.94
£61.94
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Just does not seam to do a job
Reviewed by Anonymous on 07/04/2015
I have used this cooler and even the lower end CPU's still get scary hot.
Scroll to top
