BT.com
Wishlist
Akasa Intel 1U all copper active cooler with PWM blower fan for LG
Akasa Intel 1U all copper active...
£31.34
£31.34
Add to wishlist
Delivery
Standard Due date unavailable
The long life two-ball bearing fan draws the cool air though the fins and extracts hot air to one side to support chassis airflow. Dual mounting with spring-loaded screws and motherboard backplate guarantee safe retention. Thermal compound and LGA775 / LGA115X backplates are provided.
  • Active LGA775 & LGA115X cooling solution
  • Side blow fan
  • Solid copper heatsink
  • Reliable and long life twin ball bearing fan
Akasa AK CCE-7107BP - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Copper
Fan Diameter
77 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1200-5500 rpm
Air Flow
11.83 cfm
Noise Level
45.99 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
8.99 cm x 8.62 cm x 3.05 cm
Processor cooler
Package Content
Thermal paste
8.99 cm
8.62 cm
3.05 cm
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fan Diameter
77 mm
Fan Height
15 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
1200-5500 rpm
Air Flow
11.83 cfm
Air Pressure
20.66 mm
Noise Level
45.99 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
MTBF
80,000 hours
Akasa Intel 1U all copper active cooler with PWM blower...
£31.34
Save on this ideal PC Build kit!
Save £16.94
£56.72
Scroll to top
