Click to visit BT.com
BT.com
Wishlist
Akasa Integral P2 2.5" eSATA/USB External Storage Enclosure
4.0*
Quicklinx: 4THSWS00
Mfr#: AK-ENP2NES-BK
This aluminum enclosure is compact and light, perfect for the mobile lifestyle. The sleek aluminum body enables efficient heat dissipation. Blue LED power and access indicator gives it a touch of real style.
This external enclosure enables you to connect to both legacy and new PC technology. So investment in technology is not lost.
Akasa Integral P2 AK-ENP2NES-BK - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
Storage enclosure - external
Bus Type
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
USB bus
Microsoft Windows 2000, Apple MacOS 9.0 or later, Microsoft Windows XP, Microsoft Windows Vista
8 cm x 15.1 cm x 1.6 cm
2.5"
Host Bus
Product Material
Aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - 7 pin Serial ATA ( internal )
1 x USB 2.0 - 4 PIN USB Type A , 1 storage - eSATA-300 - 7 pin external Serial ATA
Carrying case, USB (power) cable
1 x USB cable , 1 x eSATA cable
Mounting Kit
Included
Plug and Play
Power Source
USB bus
8 cm
15.1 cm
1.6 cm
Customer reviews
Write a review for the Akasa Integral P2 2.5" eSATA/USB External Storage Enclosure here!
Fantastic Casings
Reviewed by Gary. Review Posted 17/11/2009
The fact that you don't need a power adapter to run eSata mode is fantastic.
The speed is fantastic and the cover you get makes these casings ideal and very neat.
If you have 2.5 inch SATA drives that you want to use on your laptop then these casings are for you.
I bought two now I have 1.25TB HDD space running SATA drives on my lattop :-)
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great drive enclosure
Reviewed by Ian. Review Posted 27/02/2009
This must be one of the best 2.5" caddies. Internally you can install either an IDE or SATA drive. Externally you can connect it to your computer with either USB or eSATA (note you can only use USB with an IDE drive).
The unit comes with the following cables:
1) USB cable to power the unit
2) USB data cable
3) eSata to eSata data cable
It's very easy to install and set up and it comes with a nice soft carry case.
I installed a 320GB Western Digital SATA drive for a great backup/portable drive setup.
All in all highly recommended.
  • Overall 5*
  • Ease of use 5*
Great item
Reviewed by The Regsy. Review Posted 08/08/2012
I bought one after realising that the new hard drive I'd bought for my laptop was too fat, 12.5mm instead of 9.5mm so I bought one of these to use the drive externally, set up and installation was easy to do, case is well constructed and feels solid, it is however a little larger than some of the others I have used, no doubt due to the fact it will accept the larger drive and has IDE and ESata compatibility built in. Great item and very recommended.
  • Overall 5*
  • Ease of use 5*
Faulty Item and needs separate USB for power
Reviewed by Will. Review Posted 09/08/2012
Had high hopes for this product but after just a couple of days it developed a fault where the power connector has to be held in at a certain angle or the devices loses power, potentially damaging the drive inside. Also didn't realise that when using the eSATA cable the unit also needs to be plugged into a separate USB port for power - as my laptop only has 3 USB sockets (one of which is the combined USB/eSATA), it means using this device only leaves one USB port free which isn't ideal.
  • Overall 1*
  • Ease of use 2*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
