BT.com
Wishlist
Akasa Heatsink and Fan Sockets 775 1150 1151 1155 1151 1155 1156
Akasa Heatsink and Fan Sockets 775...
£10.81
£10.81
Add to wishlist
Delivery
Standard Due date unavailable
The low noise AK-959 uses a high engineered multi directional heatsink with copper core and bi-ped fins providing cost effective efficient CPU and motherboard cooling. The PWM fan is regulated automatically by CPU usage so under normal PC work load the fan speed is low ensuring quiet computing but extra performance is available when needed.
Intel approved pushpins ensure easy installation, reliable retention and maximum compatibility on both LGA775 and LGA1156 platforms without any mounting adjustment, pushpins will automatically slide into correct position.
AK-959CU is designed to work with CPU's up to 115 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Akasa AK 959CU - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium with copper base
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
55.4 cfm
Noise Level
11.7 - 28.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
9.5 cm x 9.5 cm x 6.2 cm
340 g
Processor cooler
9.5 cm
9.5 cm
6.2 cm
340 g
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
55.4 cfm
Air Pressure
4.3 mm
Noise Level
11.7 - 28.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.26 A
Mounting Kit
Included
MTBF
40,000 hour(s)
Akasa Heatsink and Fan Sockets 775 1150 1151 1155 1151...
£10.81
Save on this ideal PC Build kit!
Save £10.63
£29.98
Scroll to top
