BT.com
Wishlist
Akasa Galileo Fanless Solid Aluminium THIN Mini-ITX Case
Delivery
Standard Due date unavailable
Galileo: Ultra-slim fanless Thin Mini-ITX case
  • Aluminium fanless CPU cooling design
  • Ideal for business, education and embedded environments
  • Form factor: Thin Mini-ITX 6.7" X 6.7"
  • Suitable for VESA mounting
  • Antenna fitting holes
  • Kensington lock
  • Less than 37mm in height
  • Optional 120W or 150W external power adapter
Spec
  • Material Aluminium and heatpipes
  • Motherboards types Thin Mini-ITX 6.7" X 6.7"
  • Dimensions 307 x 190 x 36.8mm (W x D x H)
  • Weight 1730 g
  • Antenna fitting holes 2
  • Security Kensington lock
  • VESA mounting Support
Akasa Galileo - ultra small form factor - Thin mini ITX
System cabinet
Ultra small form factor
Supported Motherboards
Mini-ITX, Thin mini ITX
System Cabinet Features
Heatpipe CPU cooling, made of aluminium, VESA mounting interface, Kensington lock support, aerial fitting holes
Power adapter 120 Watt
30.7 cm x 19 cm x 3.68 cm
1.73 kg
Max Mainboard Size
Thin mini ITX
Thermal paste, washer, rubber feet, securing screws, Intel back plate, thermal module base with clip, top plate, heatpipe, VESA mounting screws
Power adapter
Power Provided
120 Watt
30.7 cm
19 cm
3.68 cm
1.73 kg
Scroll to top
