BT.com
Wishlist
Akasa Dual Socket Value Cooler LGA775/1156 with 80mm PWM Fan
Akasa Dual Socket Value Cooler...
£8.10
£8.10
Add to wishlist
Delivery
Standard Due date unavailable
AK-CCE-7102EP is a modern design value CPU cooler offering efficient and low noise cooling. High engineered multi directional aluminum heatsink with bi-ped fins maximizes heat dissipation and provides optimal CPU and motherboard VRM cooling. Intel approved 4-pin PWM fan ensures the RPM is automatically regulated by the motherboard according to CPU usage and temperature. This means under normal operating conditions, the CPU fan speed is relatively low maintaining low noise levels.
AK-CCE-7102EP is designed to work with CPU's up to 73 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Akasa AK CCE-7102EP - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
39.2 cfm
Noise Level
29 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Blue LEDs, Pulse-width modulation (PWM) support
9.5 cm x 9.5 cm x 5.3 cm
246.6 g
Processor cooler
9.5 cm
9.5 cm
5.3 cm
246.6 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo , Core i3 , Core i5
Heatsink Material
Aluminium
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
EBR bearing
Rotation Speed
600-3000 rpm
Air Flow
39.2 cfm
Air Pressure
3.56 mm
Noise Level
29 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.24 A
MTBF
40,000 hour(s)
Scroll to top
