BT.com
Wishlist
Akasa Dual Socket Aluminium Cooler LGA775/1156 with 92mm PWM Fan
Akasa Dual Socket Aluminium Cooler...
£10.08
£10.08
Add to wishlist
Delivery
Standard Due date unavailable
The ultra quiet AK-CCE-7101CP uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. The fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
AK-CCE-7101CP is designed to work with CPU's up to 95 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Akasa AK CCE-7101CP - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Ball bearing
Rotation Speed
600-3000 rpm
Air Flow
55.4 cfm
Noise Level
11.7 - 28.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9.5 cm x 9.5 cm x 6.3 cm
362 g
Processor cooler
Package Content
Thermal paste
9.5 cm
9.5 cm
6.3 cm
362 g
Heatsink & Fan
Compatible With
Processor Compatibility
Pentium 4 , Core 2 Duo , Core 2 Quad , Core i3 , Core i5 , Core i7
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Ball bearing
Rotation Speed
600-3000 rpm
Air Flow
55.4 cfm
Air Pressure
4.3 mm
Noise Level
11.7 - 28.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.26 A
Mounting Kit
Included
MTBF
40,000 hour(s)
Scroll to top
