BT.com
Wishlist
Akasa Dual Socket Aluminium Cooler (Designed for Intel Pentium 4, Core2Duo, Core2Quad, Core i3, i5, i7)
Akasa Dual Socket Aluminium Cooler...
£9.24
Hurry, only 1 left in stock!
£9.24
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Ultra Quiet AK-CCE-7104EP uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. The Enter bearing fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
Intel approved pushpins ensure easy installation, reliable retention and maximum compatibility on both LGA775 and LGA1156 platforms without any mounting adjustment, pushpins will automatically slide into correct position.
AK-CCE-7104EP is designed to work with CPU's up to 95W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
  • High engineered aluminium heatsink for cost effective performance
  • Bi-ped fins maximise heat dissipation
  • Ultra Quiet Enter bearing PWM fan
  • Push-pin mounting provide easy and reliable retention
  • Intel LGA775 and LGA1156 compatible
  • Performance thermal interface pre-applied
Spec
  • Socket type Intel LGA775 & LGA1156
  • Cooler dimensions 94.8 X 94.8 X 62.3 mm
  • Heatsink material Aluminium fins and core
  • Weight 326g
  • Installation Push-pins
  • Fan dimension Ø92 x 25 mm
  • Fan speed 600 - 3000 RPM (PWM controlled)
  • Max airflow 56.81 CFM (96.2 m³/h)
  • Max air pressure 4.05 mm H2O
  • Noise level 17.2 - 30.54 dB(A)
  • Current rating 0.26A
  • Voltage rating 12V DC
  • Bearing type Enter Bearing
  • Fan life expectancy 40,000 hours
  • Fan connector 4pin PWM
Socket
Cooler Dimensions
94.8 x 94.8 x 62.3 mm
Akasa Dual Socket Aluminium Cooler (Designed for Intel...
£9.24
Save on this ideal PC Build kit!
Save £10.36
£28.79
Scroll to top
