BT.com
Wishlist
Akasa Dual 2.5" SSD/HDD mounting module for 3.5" Bay, Black aluminium
Akasa Dual 2.5" SSD/HDD mounting...
£7.62
£7.62
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Mounting kit AK-MX010 allows two notebook drives to fit into a standard 3.5" drive bay of the PC case. Introduce technology high-speed SSD (solid state drives) or make use of laptop HDD in your PC. High-grade aluminum enables rapid heat dissipation.
Akasa AK-MX010 - storage bay adapter
Storage bay adapter
Supported Form Factor
3.5" to 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bays
1 3.5"
Product Material
Aluminium
10.1 cm x 11.4 cm x 2.4 cm
145 g
Storage bay adapter
3.5" to 2.5"
Product Material
Aluminium
Bays
2 x internal - 2.5"
Compatible Bays
1 x internal 3.5"
Mounting Kit
Included
10.1 cm
11.4 cm
2.4 cm
145 g
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Not Suitable for all cases
Reviewed by Anonymous on 12/07/2011
I recently purchase a Momentus XT 2.5 Inch hard drive and was looking for an adatper to fit it in to a 3.5 inch cage in my Antec P180 Case. Having purchased AKASA components before and having always been very satisfied with them this was my initial choice. The quality of this bracket was no exception and it came with all the necessary screws. However when trying to install it, I found that it did not fit the HD Cage. The Antec P180 has very specific mounting positions for drives and this bracket was too short. The bracket is 114mm in length and the "3.5 inch" screw holes are 60mm apart. It could be the same for other custom/enthusiast cases. I will find a use for it in another build I am sure.
1* Looks great but does not fit
Reviewed by Hamish Dumbreck on 13/04/2013
Like the other review I see for this item, the mounting holes do not match the holes for the standard IDE HDD bay. Also to note, that the large gap between the appature and the SSD would stress the SSD if the screws were to be tightened... Having looked for alternative solutions, I would recommend the DYNAMODE adaptor, made from plastic with flexibility to avoid stressing the SSD mounting positions. The point of having a chunky aluminium mounting to dissapate the heat is lost, A because an SSD does not generate a significant amount of heat, and B, without a good mounting contact surface, any heat would not be dissapated.
Scroll to top
