BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Akasa Crypto Stylish Media Mini ITX Case
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Building on the experience of the successful Enigma case Akasa has developed this high performance yet compact mini-ITX case. The desirable sleek fascia panel of the Crypto case makes it perfect for multimedia applications.
The new slightly larger design incorporates a new bay layout giving improved airflow and easier cable routing, this makes the system build simpler. Now compatible with all mini-ITX boards including embedded, AMD Socket AM3 and Intel LGA775.
2 bays are included: 2.5" HDD and slimline optical drive. ON the front panel are HD audio and two USB ports for easy connectivity.
  • Designed for ultra compact systems
  • Stylish design for multimedia applications
  • Compatible with all mini-ITX motherboards
Scroll to top
