BT.com
Wishlist
Akasa Crypto Media Mini ITX Case - VESA Edition
Akasa Crypto Media Mini ITX Case -...
£71.86
£71.86
Add to wishlist
Delivery
Standard Due date unavailable
Building on the experience of the successful Enigma case Akasa has developed this high performance yet compact mini-ITX case. The sleek fascia panel makes it perfect for multimedia applications while optional security features like Kensington security slot, intrusion alarm facility and case locking tab makes it a perfect solution for both business and education environments.
The new slightly larger design incorporates a new bay layout providing improved airflow and easier cable routing, this makes the system build easier. Now compatible with all mini-ITX boards including embedded, AMD Socket AM3 and Intel LGA775,1156.
2 bays are included: 2.5" HDD and slimline optical drive. On the front panel are HD audio and two USB ports for easy connectivity.
Stylish and easy fit design, compatible with standard Vesa mount LCD monitors. Save space and be Secure!
  • Designed for ultra compact systems
  • Ideal for business and education environment
  • Stylish design for multimedia applications
  • Compatible with mini-ITX motherboards
  • VESA mounting compatible (10mm)
Akasa Crypto Vesa - desktop slimline - mini ITX
System cabinet
Desktop slimline
Smooth black
United Kingdom
I/O Connectors
2 x USB 2.0 , 2 x audio
Supported Motherboards
Mini-ITX
Power adapter 80 Watt
Motherboard Power Connectors
24-pin main power connector, 4-pin ATX12V connector
Specification Compliance
ATX12V
24.5 cm x 22.7 cm x 6.8 cm
Desktop slimline
Max Mainboard Size
Mini ITX
Mini-ITX
ATX12V
Internal Bays Qty
1
Front Accessible Bays Qty
1
Smooth black
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 1 (total) / 1 (free) x internal - 2.5"
2 x USB 2.0 , 2 x audio - mini-jack
SATA cable
Power adapter
Power Provided
80 Watt
24.5 cm
22.7 cm
6.8 cm
£71.86
Save on this ideal PC Build kit!
Save £8.43
£91.08
Scroll to top
