Click to visit BT.com
BT.com
Wishlist
Akasa Crypto, Stylish Media Mini ITX Case, with 80W external AC adaptor
Quicklinx: 6NWKWS00
Mfr#: AK-ITX02BK08UK
Building on the experience of the successful Enigma case akasa has developed this high performance yet compact mini-ITX case. The desirable sleek fascia panel of the Crypto case makes it perfect for multimedia applications while optional security features like Kensington security slot, intrusion alarm facility and case locking tab makes it suitable solution for both business and education environments.
The new slightly larger design incorporates a new bay layout giving improved airflow and easier cable routing, this makes the system build simpler. Now compatible with all mini-ITX boards including embedded, AMD Socket AM3 and Intel LGA775.
2 bays are included: 2.5" HDD and slimline optical drive. ON the front panel are HD audio and two USB ports for easy connectivity. Available with optional 60W or 80W external power adapter.
  • Designed for ultra compact systems
  • Ideal for business and education environment
  • Stylish design for multimedia applications
  • Compatible with all mini-ITX motherboards
Colour: Smooth black Dimensions : 245(W) x 222.5(D) x 68(H) mm Material: Steel body, ABS front panel Motherboard type: Mini ITX External bays :1 (for slim optical drive) Internal bays :1 (for 2.5" HDD) Fan dimensions: 50 x 50 x 15mm Fan Bearing Type :Sleeve bearing Fan Speed :4000 RPM USB ports :2 at front Audio I/O ports :HD Audio in/out at front Power connectors: 24pin motherboard 4pin ATX12V 4pin Molex SATA power
Case Form Factor
Mini tower
Motherboard Form Factor
Mini ITX
Power Supply
80 Watt
Silver
