BT.com
Wishlist
Akasa Compact AMD CPU Cooler
£7.26
Hurry, only 1 left in stock!
£7.26
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The AK-865 is a new design cooler combining lo-noise, efficient cooling with great value. Only 50mm of height (including fan) means it can be installed even in very compact cases. Hi-engineered aluminium heatsink and quiet 80mm fan ensure optimized performance with all AMD processors up to 89W or TDP. Thermal compound is pre-applied.
  • High engineered aluminium heatsink for cost effective cooling performance
  • 8 cm low noise high performance fan
  • new design one point clip enables quick and safe retention
  • 3-pin fan connector Hi-grade thermal interface pre-applied
Manufacturer
Akasa
Product Line
Akasa AK
Model
865
£7.26
Save on this ideal PC Build kit!
Save £9.28
£26.85
Scroll to top
