BT.com
Wishlist
Akasa Chipset cooler, 3 Blue LED lo-noise Thermally Cond
Akasa Chipset cooler, 3 Blue LED...
£6.30
Hurry, only 1 left in stock!
£6.30
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
AK-210 Cool Blue chipset cooler. Keep your chipset cool in style. The lo-noise fan has 3 Hi-bright blue LED's and sits on a blue heatsink. The cooler is easily installed using the thermally conductive adhesive transfer tape.
  • Lo-noise Chipset cooler.
  • 3 Hi-bright blue LED fan on Blue heatsink.
  • Lo-profile, only 24mm high.
  • Thermal conductive adhesive transfer tap (DG765) pre-applied.
  • Tool free and easy installation.
Akasa Cool Blue AK-210 - chipset cooler
Chipset cooler
Fan Diameter
40 mm
Fan Bearing
Sleeve bearing
Rotation Speed
5000 rpm
Air Flow
5.2 cfm
Noise Level
23 dBA
Blue LED fan
Chipset cooler
Heatsink & Fan
Fan Diameter
40 mm
Fan Bearing
Sleeve bearing
Rotation Speed
5000 rpm
Air Flow
5.2 cfm
Noise Level
23 dBA
Blue LED fan
Akasa Chipset cooler, 3 Blue LED lo-noise Thermally...
£6.30
Save on this ideal PC Build kit!
Save £10.36
£25.85
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* great
Reviewed by Lee Murphy on 15/05/2007
well done to akasa again all my cooling kits are supplied by them and all do what they say on the box this little chipset cooler is well easy to install (But u might have probs removing the original first) has a nice big heat sink with a proper silent fan and comes in a wicked cool blue cooler to with blue leds
5* sticky pad?
Reviewed by MikeT on 18/12/2008
To those buyers slagging of Akasa for using thermal tape - the tape they use is generally being acknowledged as the best in the industry and does a remarkable job.
After using it literally thousands of times over the last 10 or so years, I suspect you failed to clean your old chip of the previous heatsink bonding material - that would definitely have caused the slippage.
A bit of isopropy will do the job, or at a push - vodka :)
1* Do not buy this!
Reviewed by Sim on 19/02/2008
This chipset cooler attached by way of a sticky pad, it keeps falling off. Why couldn't it be attached via pins and heatsink paste? Other than that it's great
1* Worthless
Reviewed by Richard on 01/09/2008
This product is appalling and certainly not fit for purpose. The heat sink and fan seem OK and the fan is quiet BUT... Why the hell did they decide that a heat sink can be affixed to a chipset using a sticky pad? It just does not stick making it completely worthless. Even super-cheap sellotape is stickier that the pad and there is no luxury such as heat conducting paste. My advice - DO NOT BUY THIS JUNK. Sorry BT, usually your products are so good too.
Scroll to top
