Click to visit BT.com
BT.com
Wishlist
Akasa Aluminium Libra Ergonomic Notebook Cooler up2 15.4
Quicklinx: 55F1WS00
Mfr#: AK-NBC-08AL
Essential accessories
Libra is a lightweight notebook cooler for use on the go. Specially designed air intakes and side recesses for easy handling allow the cooler to sit on your desk or lap were ever you are and effectively cool your notebook PC. This keeps the noise level of internal PC fans to a minimum providing a quieter working environment. The cooling performance will be enhanced when using the notebook on full load.
Airflow generated by two ultra quiet fans plus full size aluminum face panel helps dissipate the heat quickly. Ergonomically shaped aluminum surface with seven rubber non-slip pads ensure comfortable and stable notebook operation. Easy to use: no software to install, powered directly from your notebook with included USB cable. An on/off fan switch is fitted for passive operation and an additional USB port for low-power devices.
Akasa LIBRA AK-NBC-08AL - notebook fan with 1 port USB hub
Notebook fan with 1 port USB hub
Package Content
USB cable
Brushed aluminum
Noise Level
21.5 dBA
33.4 cm x 27.5 cm x 3.6 cm
0.72 kg
Non-slip feet, USB powered, on/off switch
Package Content
USB cable
33.4 cm
27.5 cm
3.6 cm
0.72 kg
Brushed aluminum
Heatsink & Fan
Noise Level
21.5 dBA
