BT.com
Wishlist
Akasa 8cm Blue uV Reactive Fan Low Noise
Akasa 8cm Blue uV Reactive Fan Low...
£4.68
£4.68
Add to wishlist
Delivery
Standard Due date unavailable
AK-176BL-S Keep your cool with Akasa UV reactive case fans. Blue, Green or Orange, cool it with colour.
  • Blue UV reactive fan
  • Lo-noise case fan
  • Blue UV 3 to 4-pin adapter
  • 4 case screws
Akasa AK 176BL-S - system fan kit
System fan kit
UV-blue
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
32.4 cfm
Noise Level
27.85 dBA
Power Connector
3-pin plug, 4 pin Molex connector
80 mm x 80 mm x 25 mm
Package Type
Retail
System fan kit
80 mm
80 mm
25 mm
UV-blue
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
32.4 cfm
Noise Level
27.85 dBA
Power Connector
Mounting Kit
Included
Package Type
Retail
Scroll to top
