BT.com
Wishlist
Akasa 80mm Crystal Blue case Fan - Blue LED
Akasa 80mm Crystal Blue case Fan -...
£5.40
£5.40
Add to wishlist
Delivery
Standard Due date unavailable
Akasa is the leader in thermal integration solutions. Basing on quality and consistency, Akasa continues to produce new and innovative components to excite the high-end market.
PRODUCT FEATURES:
  • 8cm Crystal Blue Fan
  • 4 Blue Color LEDs
  • Fan life expectancy 30,000 hours
  • 3pin Connector
Akasa AK 170CB-4BLS - fan unit
Fan unit
Crystal blue
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
28.8 cfm
Noise Level
27.45 dBA
Fan unit
Crystal blue
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
2500 rpm
Air Flow
28.8 cfm
Noise Level
27.45 dBA
Akasa 80mm Crystal Blue case Fan - Blue LED...
£5.40
Save on this ideal PC Build kit!
Save £10.63
£24.57
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* best value and wicked colour
Reviewed by on 31/05/2008
Great colour especially against black case, quiet and you cant beat the price on-line or on the high street.
Had to create screw teeth (bit screw fits into couldn't remember name)
But just connect it to power supply to find out which way is which. screw the screws in and hey prestow.
Scroll to top
