BT.com
Wishlist
Akasa 750W Venom Power Modular PSU
Delivery
Standard Due date unavailable
  • Modular cable management enhances airflow
  • Dynamic single 12V rail for power hungry hardware
  • Thermally controlled ultra quiet fan
  • Unique fan frame design enhances airflow
  • Semi modularized design
Spec
  • Application 750W PC Power Supply
  • Designed for AMD / INTEL based systems
  • ATI-AMD / NVIDIA graphics
  • Form factor ATX 12V 2.3
  • Dimensions 150 x 158 x 86mm (W x L x H )
  • Typical efficiency Over 80%
  • Power Factor Correction Active PFC
  • Fan 135 x 135 x 25mm, thermal control
  • Motherboard connector 1 (20+4pin )
  • ATX12V connectors 1 (4+4pin)
  • PCIe 6+2pin connectors 2
  • SATA connectors 6
  • Molex 4pin connectors 6
  • FDD 4pin connectors 2
  • AC power input 240V AC
  • Protection Over Power / Voltage / Current Protection
Akasa Venom Power - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
12 x 15 pin Serial ATA power , 8 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x power 24 pin ATX with detachable 4 pin section , 4 x 6 pin PCI Express power , 1 x power 8 pin +12V with detachable 4 pin section
Cooling System
140 mm fan
15 cm x 15.8 cm x 8.6 cm
ATX12V 2.3
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 24 A , +5V - 30 A , +12V1 - 62 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
80%+
Power cable
Cooling System
140 mm fan
Over current protection, over voltage protection, overpower protection, single 12V rail, temperature controlled fan
15 cm
15.8 cm
8.6 cm
Scroll to top
