BT.com
Wishlist
Akasa 750W Cobra Modular Power Supply (PSU) with Strip Ribbon Cabling
Akasa 750W Cobra Modular Power...
£72.73
£72.73
Add to wishlist
Delivery
Standard Due date unavailable
750W modular PSU, use the cable you need to reduce clutter. Akasa Cobra PSU features Dynamic single 12V rail for power hungry hardware.
  • Modular cable management enhances airflow.
  • Dynamic single 12V rail for power hungry hardware.
  • Thermally controlled ultra-quiet fan.
  • COBRA strip cable is neat and manageable.
Akasa Cobra 750 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 16 cm x 8.6 cm
ATX12V 2.3
United Kingdom
Input Voltage
AC 240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 22 A , +5V - 22 A , +12V - 56 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
82%
Cooling System
135mm fan
Over current protection, over voltage protection, overpower protection, cable management, single 12V rail, temperature controlled fan
15 cm
16 cm
8.6 cm
Akasa 750W Cobra Modular Power Supply (PSU) with Strip...
£72.73
Save on this ideal PC Build kit!
Save £10.63
£91.90
Scroll to top
