Click to visit BT.com
BT.com
Wishlist
Akasa 3.5" Mounting Adapter for Device/SSD/HDD
Quicklinx: 7SPXWS00
Mfr#: AK-HDA-05
Stock Status: Clearance
Express delivery Order within the next 3 hours for delivery tomorrow
Hurry, only 3 left in stock!
£7.50
Mounting adapter allows a 3.5" device, 3.5" HDD or 2.5" SSD/HDD to fit into a 5.25" PC drive bay.
Spec
  • Application Mounts single 3.5" device, 3.5" HDD or 2.5" SSD/HDD in a 5.25" PC bay
  • Designed for 3.5" device, 3.5" HDD or 2.5" SSD/HDD
  • Material Plastic
  • Dimensions 154.5(L) x 149(W) x 42.2(H) mm
  • Weight 96g
Akasa AK-HDA-05 - storage bay adapter
Storage bay adapter
Supported Form Factor
5.25" to 3.5" / 2.5"
Expansion Bays
1 x internal - 2.5" / 3.5" shared
Compatible Bays
1 5.25"
Product Material
Plastic
14.9 cm x 15.5 cm x 4.2 cm
96 g
Storage bay adapter
Product Material
Plastic
Bays
Compatible Bays
1 x internal 5.25"
14.9 cm
15.5 cm
4.2 cm
96 g
Akasa 3.5 Bundle deal on Akasa 3.5" Mounting Adapter for Device/SSD/HDD
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£17.49
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£11.59
saving £0.88
Brand: Akasa
Price Range Inc VAT: 0 - 50
