BT.com
Wishlist
Akasa 3.5" Internal 6-Slot Multicard Reader with USB 3.0
Akasa 3.5" Internal 6-Slot...
£11.35
£11.35
Add to wishlist
Delivery
Standard Due date unavailable
Makes reading media cards so much easier
Conveniently positioned at the front of your PC, this six slot media card reader accepts most available cards in a single location. Includes a SuperSpeed USB3.0 port for fast connectivity. Choice of black or classic-white front facia plates. Simple installation.
  • Super speed USB3.0 connection
  • Backwards compatible with USB2.0
  • 6-slots card reader
  • Choice of fascia colour
Specification
  • Application 3.5" PC bay
  • Memory card slots 6
  • Memory card types Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra) Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) , 64GByte for SDXC - 32GByte for SDHC Extreme Digital (X card, Type H, Type M) M2 (Memory Stick Micro M2) microSD (microSDHC, High Capacity)
  • Interface 5Gb/s (USB3.0) and 480Mb/s (USB2.0)
  • Data transfer rate USB 3.0 port: up to 5Gb/s (USB 3.0) and 480Mb/s (USB 2.0)
  • Card reader: up to 480 Mb/s
  • LED indication Power On, Card In & Data Transfer
  • Power mode USB powered
  • PC connection Internal USB motherboard header, USB3.0 A male connector
  • Supported OS Windows 2000 / XP / VISTA / 7
  • Plug & Play Supported
Please note the USB 3.0 connection is acheived via an external cable. If you required internal USB 3.0 connection via a 19pin header please consider QL 8205 (Akasa Code: AK-ICR-14)
Akasa Internal Card Reader - card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 3.0
Required Bay
3.5" internal
Host Interface
USB 3.0
Required Bay
3.5" internal
Microsoft Windows 2000/XP/Vista/7
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Bad design and not enough info on which way cards are inserted
Reviewed by Richard Lodge on 24/01/2014
Could not get the compact flash card to appear in my computer. After messing around for ages checking device manager and downloading new usb drivers I inadvertently place the compact flash card in upside down and it worked. One would assume that the cards would only go in one way as they do in the camera. However if the card was meant to go in upside down there was no indication as such on the cover. Bad information and labelling on the product. I have put a label on the front of the product as a reminder that compact flash cards go in upside down. Obviously the poor design of the product allows this. Anyway it now works.
1* Flaky, poor quality
Reviewed by Anonymous on 04/04/2015
Yes, CF cards have to go in upside down and if inserted anything but completely aligned won't show up... SD cards sometimes read, sometimes don't... and the entire thing dies after around a year of use. Avoid.
1* Don't buy this
Reviewed by David Large on 21/11/2012
I bought this card reader for a new PC I was building and sadly I cannot recommend it. The connections are one internal USB2 and one standard (external type)USB3 connector that had to come outside the system box and plug into the back panel. It requires both to show any sort of functionality. Although disk drives showed in disk administrator and the device detected cards the cards did not show up in windows explorer so in effect the reader was useless.
1* Bad product design
Reviewed by Jim on 19/04/2013
I bought one of these from another company. The CF slot does not function properly. You have to to push the card in very quick, so the power pins make contact at the same time as the data pins. If you don't do this, the card does not show up in Windows.
Check forums before thinking about buying this or any card reader from Akasa.
Scroll to top
