BT.com
Wishlist
Akasa 3.5" 6 Internal 6-Slot Media Card Reader
Akasa 3.5" 6 Internal 6-Slot Media...
£11.04
£11.04
Add to wishlist
Delivery
Standard Due date unavailable
This 6-port Media Card Reader can be conveniently positioned at the front of your PC enabling the reading of all popular memory cards in a single location. Compatible with high capacity memory cards (SDHC), has dedicated ports for microSD and M2 ports, this eliminates the need for any card adapters.
Additional USB port provides extra connectivity for convenient data transfer from USB memory sticks or USB enabled mobile phones. Designed to fit 3.5" PC bay. Two LED's indicate power on, card in and data transfer.
  • 6-port card reader
  • Supports all popular memory cards
  • Accepts microSD and M2 cards without adapters
  • High capacity cards (SDHC) compatible
  • Additional USB port ideal for USB memory sticks
  • High transfer rate with USB 2.0
  • Easy to install
Scroll to top
