BT.com
Wishlist
Akasa 18cm Ultra Quiet Case Fan on 14cm fitting
Delivery
Standard Due date unavailable
Ideal for DIY modding or as a replacement for an existing 18cm chassis fan. Crystal clear fan adds style to the PC case. The seven large fan blades provide massive airflow cooling all system components at a very low speed, which makes the fan virtually silent.
Provides 51.86CFM of airflow, which when directed towards the motherboard, VGA cards and RAM can significantly improve the system stability and give you an extra edge. It might be crucial at the next LAN PARTY.
  • Ultra quiet
  • Precision balanced low air impedance fan blades
  • New design 18cm fan with 14cm fittings
Akasa AK F1825SM - case fan
Case fan
Package Content
Screws
Crystal Clear
Fan Diameter
180 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
600 rpm
Air Flow
51.9 cfm
Power Connector
4 pin Molex connector
18 cm x 18 cm x 2.5 cm
Case fan
Package Content
Screws
18 cm
18 cm
2.5 cm
Crystal Clear
Heatsink & Fan
Fan Diameter
180 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
600 rpm
Air Flow
51.9 cfm
Power Connector
Mounting Kit
Included
Sound Emission
15 dBA
Scroll to top
