BT.com
Wishlist
Akasa 14cm crystal clear fan W/4 Red LED,
Delivery
Standard Due date unavailable
AK-FN075 is an ultra quiet 14 cm case fan delivering high air volumes with low noise acoustic performance of 22.8 dB(A). The cool red effect is achieved by using four bright red LEDs. Crystal clear frame allows the light to spread providing maximum system illumination to add subtle style to any PC system.
Akasa Quiet Red LED AK-FN075 - case fan
Case fan
Package Content
Tool-less fixed pins
Crystal Clear
Fan Diameter
139 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
56.5 cfm
Noise Level
22.8 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Red LED x4
13.9 cm x 13.9 cm x 2.5 cm
Anti-vibration
Case fan
Package Content
13.9 cm
13.9 cm
2.5 cm
Crystal Clear
Heatsink & Fan
Fan Diameter
139 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
56.5 cfm
Air Pressure
0.84 mm
Noise Level
22.8 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Rated Current
0.17 A
Red LED x4
Anti-vibration
Scroll to top
