BT.com
Wishlist
Akasa 14cm crystal clear fan W/4 Blue LED, fitting for 13, 13.5 &
Akasa 14cm crystal clear fan W/4...
£8.10
£8.10
Add to wishlist
Delivery
Standard Due date unavailable
An ultra quiet 14 cm case fan delivering high air volumes with low noise acoustic performance of 22.8 dB(A). The cool blue effect is achieved by using four bright blue LED's. Crystal clear frame allows the light to spread providing maximum system illumination to add subtle style to any PC system.
Akasa Quiet Blue LED AK-FN074 - case fan
Case fan
Package Content
Tool-less fixed pins
Crystal
Fan Diameter
139 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
56.5 cfm
Power Connector
3-pin plug
Rated Voltage
12 V
Blue LED x4
13.9 cm x 13.9 cm x 2.5 cm
Case fan
Package Content
13.9 cm
13.9 cm
2.5 cm
Crystal
Heatsink & Fan
Fan Diameter
139 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
56.5 cfm
Air Pressure
0.84 mm
Power Connector
3-pin plug
Rated Voltage
12 V
Rated Current
0.17 A
Blue LED x4
Sound Emission
22.8 dBA
Akasa 14cm crystal clear fan W/4 Blue LED, fitting for...
£8.10
Save on this ideal PC Build kit!
Save £8.43
£27.32
Scroll to top
