Click to visit BT.com
BT.com
Wishlist
Akasa 140mm Viper High Performance S-Flow Fan
Quicklinx: 7PPYWS00
Mfr#: AK-FN063
14cm Viper Fan: S-FLOW fan blade design delivers 30% higher airflow
High performance and PWM auto speed control
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
  • High performance 14cm fan in killer VIPER yellow colour
  • S-FLOW fan blade design delivers 30% higher airflow
  • Super silent with PWM auto speed control
  • Hydro Dynamic Bearing extends fan life up to 50,000 hours
  • Application PC case or heatsink fan
  • Dimension 140 X 140 X 25mm
  • Fan speed 600 -1600 RPM
  • Max airflow 110.61 CFM
  • Max static air pressure 3.12 mm H2O
  • Noise level 12.5 - 26.01 dB(A)
  • Voltage rating 12V DC
  • Bearing HDB (Hydro Dynamic Bearing)
  • Fan life expectancy 50,000 hours
  • Connector 4pin PWM
Akasa Viper Fan AK-FN063 - case fan
Case fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1600 rpm
Air Flow
110.6 cfm
Noise Level
12.5 - 26 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
14 cm x 14 cm x 2.5 cm
Anti-vibration
Case fan
14 cm
14 cm
2.5 cm
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1600 rpm
Air Flow
110.6 cfm
Air Pressure
3.12 mm
Noise Level
12.5 - 26 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Anti-vibration
