BT.com
Wishlist
Akasa 12cm Ultra Silent Smokey Colour Fan Blades
Akasa 12cm Ultra Silent Smokey...
£6.30
£6.30
Add to wishlist
Delivery
Standard Due date unavailable
Near silent 12 cm fan with distinctive Smokey colored rotor blades and crystal clear frame. Designed with low air impedance blades, providing the ultra quiet acoustic experience.
Akasa AK 191SM - case fan
Case fan
Clear, smoke
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1400 rpm
Air Flow
49.7 cfm
Power Connector
3-pin plug, 4 pin Molex connector
12 cm x 12 cm x 2.5 cm
Case fan
12 cm
12 cm
2.5 cm
Clear, smoke
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1400 rpm
Air Flow
49.7 cfm
Power Connector
Mounting Kit
Included
Sound Emission
18 dBA
£6.30
Save on this ideal PC Build kit!
Save £8.40
£25.52
Scroll to top
