BT.com
Wishlist
Akasa 12cm Piranha Air Ripper, Max air pressure and massive airflo
Delivery
Standard Due date unavailable
Supporting fully automatic PWM speed control, the PIRANHA uses custom design PWM IC that integrates Soft Switching Commutation (SSC) technology.
Akasa Piranha AK-FN072 - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydrodynamic bearing
Rotation Speed
600-1900 rpm
Air Flow
79.1 cfm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Anti-vibration
Case fan
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1900 rpm
Air Flow
79.1 cfm
Air Pressure
3.04 mm
Power Connector
4-pin fan connector
Rated Voltage
12 V
Mounting Kit
Included
Anti-vibration
Scroll to top
