BT.com
Wishlist
Akasa 12cm Crystal Green frame & rotor w/ 4 Green LED Fa
Akasa 12cm Crystal Green frame &...
£7.38
£7.38
Add to wishlist
Delivery
Standard Due date unavailable
This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
The fan glows a fantastic green, which adds color and style to any PC system.
Akasa Quiet Bright Green AK-274CG-4GNS - case fan
Case fan
Package Content
Screws, 3-pin plug to 4-pin Molex adapter
Crystal green
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
38.4 cfm
Power Connector
3-pin plug, 4 pin Molex connector
Variable fan speed, green LED x4
12 cm x 12 cm x 2.5 cm
Case fan
Package Content
12 cm
12 cm
2.5 cm
Crystal green
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Sleeve bearing
Rotation Speed
1200 rpm
Air Flow
38.4 cfm
Power Connector
Sound Emission
17.5 dBA
Akasa 12cm Crystal Green frame & rotor w/ 4 Green LED...
£7.38
Save on this ideal PC Build kit!
Save £16.94
£32.76
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Far more green than the photo shows
Reviewed by Anonymous on 30/06/2010
I replaced the two fans in my PC recently, and since I was going for a green theme, I went for these. I am very pleased with them!
They are much quieter than my old fans, producing nothing more than a whisper of rushing air instead of any motor noise. The colour is more of a bright apple green than the blue-green turqoise in this photograph. Thankfully, I wanted a nice bright green!
Scroll to top
