BT.com
Wishlist
Akasa 120mm Black Apache Fan , PWM, Dust and moisture proof super silent fan, HDB Bearing
Akasa 120mm Black Apache Fan , PWM,...
£13.08
£13.08
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It's powerful, quiet and tough!
  • Super silent APACHE BLACK 12cm fan
  • S-FLOW fan blade design delivers 30% higher airflow
  • IP-54 military standard moisture and dust protection
  • Super silent with PWM speed control
  • Hydro Dynamic Bearing extends fan life
Application
PC Case or heatsink fan
Dimensions
120 x 120 x 25mm
Fan speed
600 -1300 RPM
Max airflow
57.53 CFM (97.74 m3/h)
Max static air pressure
2.64 mm H2O
Noise level
6.9 -16.05 dB(A)
Current rating
0.33A
Voltage rating
12V DC
Bearing
HDB (Hydro Dynamic)
Fan life expectancy
50,000 hours
Connector
4 pin PWM
Akasa 120mm Black Apache Fan , PWM, Dust and moisture...
£13.08
Save on this ideal PC Build kit!
Save £16.90
£38.43
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Reliable so far
Reviewed by Liam on 07/02/2012
I opted to go for the expensive fans, as I knew cooling was important. These were relatively easy to setup, though you have to have some common sense about you to know which way to put the fans around (i.e which way the fans will blow air!)
The fans are mounted by plastic "pins", which are daunting to use. To secure the fan in place, you thread the "pins" through holes in the fan and your case, and pull hard, stretching them until the catches squeeze through. I was always scared that the pins would snap, as you have to stretch the rubber very far until the job is done, but they pulled through (no pun intended) and hold the fans well.
I bought two of these for my new PC to improve airflow in my case. I've had them for a few months, and they still run silently, as advertised. My components haven't had any temperature issues, either, though it is Winter, and the true test is to come.
Scroll to top
