BT.com
Wishlist
AG Neovo SX-19P 19" 1280x1024 3ms VGA DVI LCD CCTV Monitor
AG Neovo SX-19P 19" 1280x1024 3ms...
£399.99
Hurry, only 2 left in stock!
£399.99
Add to wishlist
Delivery
Standard 1-3 working days
For high efficiency surveillance performance, top security environments choose the SX-19P. The built-in image enhancer of AG Neovo's Advanced Image Platform flawlessly reproduces CCTV images at high resolutions of 625/PAL TV Lines. Eco-friendliness comes standard with RoHS, REACH and WEEE certifications and an EcoSmart sensor that slashes power consumption by up to 1/3 (versus conventional security monitors). Combined with stylish yet functional durable metal casing and edge-to-edge protective NeoV optical glass, the SX-19P transforms any surveillance room onto a security command center.
Neovo SX-19P - LCD display
LCD display
Recommended Use
Surveillance system
Supported Image Aspect Ratio
4:3
Colour Support
Display Size
19"
Resolution
1280 x 1024
LCD Technology
TFT active matrix
Video Format
NTSC, PAL, SECAM
Supported Video Signals
S-Video, composite video, VGA, DVI
Built-in Speakers
2 speakers
Picture-in-picture (PIP)
Kit Content
1 x power adapter , 1 x VGA cable
Nominal Voltage
AC 120/230 V
Max Power Consumption
34 W
LCD display
44.5 cm
17.5 cm
42 cm
7.4 kg
CCTV
Equipment Category
CCTV monitors
S-Video, composite video, VGA, DVI ; NTSC, PAL, SECAM
Audio Support
Studio & Field Monitors
Recommended Use
Surveillance system
4:3
Colour Support
Display Size
19"
Native Resolution
1280 x 1024
LCD Technology
TFT active matrix
Built-in Speakers
2 speakers
Nominal Voltage
AC 120/230 V
Frequency
50/60 Hz
34 W
Kit Content
Kit Content
( 1 ) x power adapter , ( 1 ) x VGA cable
Terminals
Terminals
( 1 ) x DVI-D - 24 pin digital DVI , ( 1 ) x VGA input - 15 pin HD D-Sub (HD-15) , ( 2 ) x composite video input - BNC , ( 2 ) x composite video output - BNC , ( 1 ) x S-video input - 4 PIN mini-DIN , ( 1 ) x audio line-in , ( 1 ) x audio line-out
10 - 90%
Scroll to top
