BT.com
Wishlist
AG Neovo SX-17P 17" 1280x1024 DVI LCD Monitor
AG Neovo SX-17P 17" 1280x1024 DVI...
£350.66
£350.66
Add to wishlist
Delivery
Standard Due date unavailable
Custom designed for security environments, the AG Neovo SX-17P is a versatile yet powerful surveillance display solution. Smart omni viewer with PIP/PAP, freeze and rotate enables superior surveillance flexibility. Slim design, looping BNC connectors, VESA compatibility and power DC-out mean effortless system integration. Plus with an EcoSmart sensor that minimizes power consumption and a durable metal frame with built-in NeoV optical glass that protects against scratches and other incidental damage, the SX-17P is truly the display of choice for today's - and tomorrow's - security environments.
Neovo SX-17P - LCD display
LCD display
Recommended Use
Surveillance system
Supported Image Aspect Ratio
4:3
Colour Support
Display Size
17"
Resolution
1280 x 1024 - 625 TVL
LCD Technology
TFT active matrix
Video Format
NTSC, PAL, SECAM
Supported Video Signals
S-Video, composite video, VGA, DVI
Built-in Speakers
2 speakers
Picture-in-picture (PIP), comb filter
Kit Content
1 x power adapter , 1 x VGA cable
LCD display
40.9 cm
17.5 cm
39.8 cm
6.7 kg
CCTV
Equipment Category
CCTV monitors
S-Video, composite video, VGA, DVI ; NTSC, PAL, SECAM
Horizontal Resolution (TV Lines)
625
Audio Support
Studio & Field Monitors
Recommended Use
Surveillance system
4:3
Colour Support
Display Size
17"
Native Resolution
1280 x 1024
LCD Technology
TFT active matrix
Built-in Speakers
2 speakers
Kit Content
Kit Content
( 1 ) x power adapter , ( 1 ) x VGA cable
Terminals
Terminals
( 1 ) x DVI-D - 24 pin digital DVI , ( 1 ) x VGA input - 15 pin HD D-Sub (HD-15) , ( 2 ) x composite video input - BNC - with loop through , ( 1 ) x S-video input - 4 PIN mini-DIN , ( 1 ) x audio line-in , ( 1 ) x audio line-out
10 - 90%
Scroll to top
