BT.com
Wishlist
AG Neovo SC-22 22" 1920x1080 3ms VGA HDMI LED Monitor
AG Neovo SC-22 22" 1920x1080 3ms...
£206.66
£206.66
Add to wishlist
Delivery
Standard Due date unavailable
The SC-22 features an LED backlight 22" widescreen display with a full HD 1920 x 1080 resolution, delivering high picture clarity. Quick signal-switching and rapid response time guarantees surveillance efficiency. With analog, HDMI, and looping BNC I/O, the SC-22 is easily integrated into any security system. Auto NTSC/PAL detection and auto settings adjustment reduce maintenance effort. Coming with built-in speakers and stylish slim profile, the SC-22 is the ideal value display choice for security and surveillance environments.
Neovo SC-22 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
3 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, S-Video, composite video
Speakers
Integrated
Display Position Adjustments
Tilt
51.65 cm x 18.5 cm x 37.6 cm
3.4 kg
Plug and Play, VESA FPMPMI, VESA EDID, CB, FCC Part 15 B, EMC, RoHS, WEEE, GOST-R, REACH
3 years warranty
Display Type
Energy Class
Class B
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
3 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.5 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Anti-Burn-in technology
3.4 kg
TV Tuner
Analogue Video Format
NTSC, PAL
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , S-video , HDMI (HDCP) , Audio line-in , Audio line-out , Composite video output (BNC) , Composite video (BNC)
Mechanical
Tilt
Tilt Angle
-6/+13
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Power Supply
Internal
AC 100/230 V (50 - 60 Hz)
25 Watt
Limited warranty - parts - 3 years
10 - 85%
Scroll to top
