BT.com
Wishlist
AG Neovo SC-17P 17" Surveillance Monitor
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
With the AG Neovo SC-17P, security centers can keep an eye on budgets without losing sight of performance. Digital and analog video inputs, including looping BNC I/O, minimize installation cost. Auto detection, settings key lock and auto settings adjustment reduce maintenance hassle. Quick signal-switching and rapid response time improve surveillance efficiency, while built-in speakers provide an additional level of security. All this and more make the SC-17P the perfect value display choice for any security environment.
Neovo SC-17P - LED monitor - 17"
LED-backlit LCD monitor - 17"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
3 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA , S-Video, composite video
Speakers
Integrated
Display Position Adjustments
Tilt
37.2 cm x 18.4 cm x 38.52 cm
2.9 kg
VESA EDID, CB, FCC, RoHS, WEEE, GOST-R, REACH
Display Type
Diagonal Size
17"
Native Resolution
1280 x 1024
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
3 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.5 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
3D comb filter, Anti-Burn-in technology, 3D Noise Reduction, 3D Deinterlace
2.9 kg
TV Tuner
Analogue Video Format
NTSC, PAL
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
Audio line-in , Audio line-out , VGA , HDMI , Composite video output , Composite video , S-video
Mechanical
Tilt
Tilt Angle
-2/+20
VESA interface support
1 x VGA cable - VGA to VGA , 1 x audio cable
AC 120/230 V ( 50 - 60 Hz )
18 Watt
10 - 95%
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
AG Neovo SC-17P 17
Item condition Customer return - item has been used and shows signs of use. No VGA/HDMI leads. Not in origianal packaging.
Ref: BDKJ 035298
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£49.32
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
