BT.com
Wishlist
AG Neovo Neovo SC-19 - LCD display - colour - 19"
AG Neovo Neovo SC-19 - LCD display...
£183.99
27 in stock
£183.99
Add to wishlist
Delivery
Standard 1-3 working days
For a cost-effective surveillance display solution, look no further than the AG Neovo SC-19. A bright, high resolution full color screen with quick signal-switching and 3ms response time ensures sharp, smooth video playback. Looping BNC video inputs and NTSC/PAL support maximize flexibility for system integration. And with built-in speakers, stylishly slim profile and VESA mountability, the SC-19 looks just as attractive as its amazingly affordable price.
LCD display
Recommended Use
Surveillance system
Supported Image Aspect Ratio
4:3
Colour Support
Display Size
19"
Resolution
1280 x 1024
LCD Technology
TFT active matrix
Video Format
NTSC, PAL
Supported Video Signals
Composite video, VGA, DVI
Built-in Speakers
2 speakers
Kit Content
1 x power adapter
Nominal Voltage
AC 120/230 V
Max Power Consumption
26 W
LCD display
42 cm
16.4 cm
40.8 cm
3.8 kg
CCTV
Equipment Category
CCTV monitors
Composite video, VGA, DVI; NTSC, PAL
Audio Support
Studio & Field Monitors
Recommended Use
Surveillance system
4:3
Colour Support
Display Size
19"
Native Resolution
1280 x 1024
LCD Technology
TFT active matrix
Built-in Speakers
2 speakers
Nominal Voltage
AC 120/230 V
Frequency
50/60 Hz
26 W
Low Voltage Power
DC 12 V
Kit Content
Kit Content
(1) x power adapter
Terminals
Terminals
(1) x DVI-I input - DVI-I , (1) x composite video input - BNC - with loop through , (1) x audio line-in - mini-phone stereo 3.5 mm
Scroll to top
