BT.com
Wishlist
Adaptec RAID 6805E Storage Controller- Serial ATA-600/SAS 2.0
Adaptec RAID 6805E Storage...
£262.81
£262.81
Add to wishlist
Delivery
Standard Due date unavailable
Adaptec series 6E unified serial SATA/SAS RAID controller delivers the robustness of hardware RAID and the Adaptec RAID code, enterprise class management features, and full OS support. Delivering the same 6 Gb/s performance of the series 6 controller, the series 6E is optimized for platform where a series 6 controller would not fit in from a price, form factor or host connectivity standpoint.
Series 6E controller supports SATA and SAS devices, and has been qualified with the same systems, motherboards, backplanes and drives as series 6 controller. It includes the same drivers, BIOS and storage management tools as series 6 controller and do not require additional training or qualification. Series 6E controller has also been thoroughly tested with entry-level storage devices for desktop use and the entry-level server platforms, workstations and motherboards most typically used for basic servers, performance workstations or industrial PCs.
Microsemi Adaptec RAID 6805E - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe x4
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe x4
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10, JBOD, RAID 1E
15.5 cm x 6.4 cm
3 years warranty
Host Bus
PCIe x4
Storage Controller
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Supported Devices
Channel Qty
8
RAID Level
PMC-Sierra PM8013
2 x SATA 6Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane SAS (SFF-8087) ( internal )
Compatible Slots
1 x PCI Express x4 - low-profile
Low-profile bracket
2 x Serial ATA / SAS cable - 4 connectors - 70 cm
MTBF
860,953 hours
UL, VCCI, C-Tick, FCC, RoHS, KCC, WEEE, REACH
Software Included
Drivers & Utilities, Adaptec Storage Manager
3 years warranty
Service & Support Details
Limited warranty - 3 years
15.5 cm
6.4 cm
55 °C
Scroll to top
