BT.com
Wishlist
Acer V227bip 27" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
Limited Time Offer
Save over £96 - Was £196.76! Hurry - Limited Stock!
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
Acer V277bip - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16.17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Matte black
61.4 cm x 20.7 cm x 46.4 cm
Environmental Standards
ENERGY STAR Qualified
TCO Displays 7.0
3 years warranty
Display Type
Energy Class
Class A+
24 kWh
16.17 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Finnish, Russian, Spanish, Dutch, Chinese
Acer Adaptive Contrast Management (ACM), ComfyView, 100% sRGB colour gamut, Zero Frame, Flicker-Less technology
Matte black
61.4 cm x 20.7 cm x 46.4 cm - with stand
VGA , DisplayPort , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
MTBF
30,000 hour(s)
TCO Displays 7.0
Power Consumption Stand by
0.37 Watt
Power Consumption Sleep
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm , Without stand - width: 61.4 cm - depth: 6.6 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
20 - 80%
Buy used stock
What is used stock?
Acer V227bip 27
Item condition Customer return - item has been repaired under warranty by the manufacturer
Ref: D9ZS 039384
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£163.56
Acer V227bip 27
Ref: D9ZS 039390
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£165.49
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
