BT.com
Wishlist
Acer V227bi 27" 1920x1080 4ms VGA HDMI LED Monitor
Select:
Not available for sale
Delivery
Standard 1-3 working days
The stunning Acer V series monitor delivers vibrant visuals and comfortable viewing ideal for extended use. Its cinematic widescreen with Full HD resolution and superior contrast ratio presents detailed imagery for prolific multitasking. What's more, this display features power-saving technologies to conserve cost and resources.
Acer V277bi - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
17 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
61.4 cm x 20.7 cm x 46.4 cm
5.85 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A+
24 kWh
17 W
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
72% NTSC colour gamut
61.4 cm x 20.7 cm x 46.4 cm - with stand
5.85 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA interface support
United Kingdom
16.2 Watt
Power Consumption Stand by
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 20.7 cm - height: 46.4 cm - weight: 5.85 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg
ENERGY STAR Certified
Scroll to top
