BT.com
Wishlist
Acer V226HQL  21.5" 1920 x 1080 5ms VGA DVI Montior
Acer V226HQL 21.5" 1920 x 1080 5ms...
£77.01
More than 50 in stock
£77.01
Add to wishlist
Delivery
Standard 1-3 working days
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
50.8 cm x 20.68 cm x 39.05 cm
3.66 kg
MPR II
3 years warranty
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
65
Vertical Viewing Angle
90
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 20.68 cm x 39.05 cm - with stand
3.66 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
MPR II
AC 120/230 V
18.1 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg
Limited warranty - 3 years
Scroll to top
