BT.com
Wishlist
Acer V196HQL 18.5" 1366 x 768 5ms VGA LED Black Monitor
Acer V196HQL 18.5" 1366 x 768 5ms...
£65.02
£65.02
Add to wishlist
Delivery
Standard Due date unavailable
Explore the angle that's perfect for you with this Professional series monitor, this monitor is wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitor. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
Acer V196HQLAb - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
44.1 cm x 19.1 cm x 35.3 cm
2.72 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307, TCO '06
3 years warranty
Display Type
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
2.72 kg
VGA
Mechanical
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
11.5 Watt
Power Consumption Stand by
0.45 Watt
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£8.20
£9.20
£9.19
£12.27
C2G VGA to Composite PC-TV Video Adapter
Quicklinx: 7CC5 | In Stock
£39.09
Scroll to top
