BT.com
Wishlist
Acer S241HLCbid 24" 1920x1080 1ms VGA DVI HDMI Monitor
Acer S241HLCbid 24" 1920x1080 1ms...
£163.04
£163.04
Add to wishlist
Delivery
Standard Due date unavailable
The Acer S1 series monitors are designed to save space and minimally impact the environment. This line of Acer monitors is super slim, and leverages various energy-saving technologies, including white LED backlighting.
Acer S241HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
56.5 cm x 16.6 cm x 40.1 cm
Environmental Standards
ENERGY STAR Qualified
MPR II, RoHS
2 years warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
24"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mercury free, Acer eColor technology, 6-bit gamma
56.5 cm x 16.6 cm x 40.1 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MPR II, RoHS
AC 120/230 V
19.8 Watt
Power Consumption Sleep
0.46 Watt
Power Consumption (Off Mode)
0.45 Watt
Dimensions & Weight Details
Without stand - width: 56.5 cm - depth: 2.4 cm - height: 34.3 cm , With stand - width: 56.5 cm - depth: 16.6 cm - height: 40.1 cm
ENERGY STAR Certified
Other bundles
Acer S241HLCbid 24
£163.04
Wireless keyboard and mouse set
£213.03
Acer S241HLCbid 24
£163.04
Keep your electronic devices protected
£183.03
Scroll to top
