Click to visit BT.com
BT.com
Wishlist
Acer S1370WHn DLP WXGA 2500 Lumens Projector
Quicklinx: 8R66WS00
Mfr#: MR.JFV11.002
The projector S1370Whn integrates all the features that are important for schools, such as short throw projection and LAN control, and it's compliant with the Crestron Network Control that enables complete management of the projector via LAN. With short throw capability this projector can display large images even when it's placed very close to the screen. Thanks to this feature presenters can avoid projector beams in the eyes and at the same time they don't cast shadows on the screen during their presentations. As a result the S1370Whn offers greater flexibility and maximum viewing comfort, making it the perfect choice for great projection in the classroom.
The Acer S1370Whn can turn any lesson into an incredible 3D experience. The three-dimensional experience is made possible by DLP 3D Ready technology that can transform the flat surface of the room wall into a 3D screen. This solution unlocks endless possibilities for engaging learning, from exploring the universe to human anatomy, from discovering geometry to touring famous archaeological sites just like being there.
Two sets of D-Sub and Audio connectors allow users to connect the projector to two PC, for more flexible connectivity and instant switching. Besides offering more connectivity options, the HDMI port provides seamless connection to the latest digital sources ensuring exceptional high-definition viewing. Thanks to Acer ColorBoost II+, the S1370Whn reproduces images with more natural and balanced shades, while it achieves a wider color gamut via Acer SpectraBoost, a color-wheel coating technology that boosts color saturation. ColorSafe II ensures color fidelity even after prolonged use.
With ExtemeEco technology the S1370Whn enables up to 70% power saving when there is no input signal for a while, helping to extend the lifespan of the lamp up to 7000 hours thus saving on lamp replacement costs and ensuring long-term, dependable projector use.
There is no need to worry about accidentally turning off the projector or wait for a cooling period before resuming the projection. The Instant resume feature allows users to turn the projector on right after it has been switched off. If the projector needs to be moved in a hurry after being used, thanks to the Instant pack feature, the power cord can be unplugged immediately without causing any damage. This feature can be very useful in case a projector needs to be moved from a classroom to the other shortly after using it.
Acer S1370WHn DLP projector - 3D
DLP projector - High Definition
3D Capable
Built-in Devices
Speaker
United Kingdom, EMEA
Brightness
2500 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL )
Speakers
Speaker(s) - integrated
AC 120/230 V
28.8 cm x 22.5 cm x 8.3 cm
2.6 kg
2 years warranty
DLP projector - HD
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2500 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
10000:1
Image Size
226 cm - 762 cm
Projection Distance
1 m - 3.4 m
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
190 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, ColorBoost Technology, SmartFormat Technology, 16:9 aspect ratio support, Short Throw Technology, EcoProjection Technology, DynamicBlack technology, Crestron RoomView, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 PIN mini-DIN , 1 x USB - 4 PIN USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45
Carrying case, lens cover, remote control
1 x VGA cable
Security Features
Nominal Voltage
AC 120/230 V
28.8 cm
22.5 cm
8.3 cm
2.6 kg
2 years warranty
Service & Support Details
Limited warranty - 2 years - carry-in
Sound Emission
32 dB
30 dB
